Symmetry Panel
Use the Symmetry panel to create symmetries that influence handles, morph volumes, domains, blocks, rwalls, and shapes.
Changes made on one subpanel do not affect the other, and are persistent so that you can switch freely between subpanels without losing any settings already made.
HyperMesh supports reflective and non-reflective symmetries.
Symmetries can be combined, but you must be careful not to create confusing symmetrical arrangements. Symmetries can also be applied to unconnected domains. In this case, the symmetric handle linking works the same as that for connected domains, but the influences between handles and nodes for non-reflective symmetries do not extend across to all domains.
Create Subpanel
| Option | Action |
| name = | Enter a name for the new symmetry that you wish to create. Alternatively, click the button twice to select an existing domains that you wish to update. Change the other settings as desired, and then click update to save the changes. |
| domains | Select the domain(s) that the new symmetry is part of. |
| morph volumes & mapping | By default, symmetries do not affect morph volumes or map to geom operations. If you wish the symmetry to affect morph volumes and mapping operations as well as domains, select this checkbox. Symmetries that affect morph volumes will affect all of the morph volumes in the model. Symmetries that affect mapping operations will affect all mapping operations, even if there are no domains in the model. |
| approximate / enforced | For reflective
                                    symmetries (1-, 2-, or 3-plane, or cyclical), choose how strict
                                    the symmetric requirements should be.
 Note: Handles created due to the enforced
                                        option may not be located on any mesh, however, they will
                                        always be assigned to the nearest domain and will affect
                                        nodes in that domain.
| (symmetry type switch) | Use this switch to pick the type of symmetry you wish to create. |
| multilateral / unilateral | For reflective
                                    different sides of the symmetry interact with each other.
| syst | Select a coordinate system with which the symmetry is aligned. |
| align with: | Define which axis of the chosen system the symmetry is aligned with: the default axis, or one of its x/y/z axes. |
| size = | Specify a size for the symmetry's visual icon. This only affects the appearance of the symmetry icon in the modeling window. |
| color | Select a color for the symmetry's icon. |
Update by Domain Subpanel
| Option | Action |
| domain | Select the desired domain. Only one domain can be selected at a time. |
| symmetries | Select the symmetries that you wish to assign to the currently selected domain. You may pick multiple symmetries. |
Command Buttons
| Button | Action |
| create | Create a new symmetry based on the settings you have specified in the create subpanel. |
| update | Update the selected symmetry to use the settings currently specified in the create subpanel. |
| review | On the create
                                    subpanel, this displays the symmetry links between the handles
                                    for the selected symmetry.  On the update by domain subpanel, review loads the symmetries associated with the selected domain into the symmetry collector.  |
| refresh | Update the symmetry
                                    links between handles.  Note: This may cause
                                        different handles to be linked and new handles to be created
                                        if the model was morphed while the symmetries were inactive
                                        or if symlinks was turned off.
| reject | Reject the creation of an entity, such as a shape or constraint. This differs from undo because undo only undoes the movement of nodes; rejecting an entity can also undo node movements, but its primary function is to delete an entity that was just created. |
| return | Exit the panel. |
