Sort Tool
Use the Sort tool to manually sort midsurfaces after extraction.
- <~[o]riginal name> comp
 - Create new components by removing the first letter of the original component name and replacing it with a ~ and sorts the midsurfaces accordingly. For example, my_comp -> ~y_comp.
 - <Midsurface #nn> comp
 - creates components with the name Midsurface #, where # increases for each component that exists for the input surfaces/solids.
 - original comp
 - organizes the midsurfaces into their parent surface/solid components.
 - <original name~> comp
 - creates components using the original component name and adds ~ at the end.
 - <original nameN> comp
 - creates new components by incrementing the name of the original.
