Spotweld Log File
A spotweld .log file is written in the directory from which HyperMesh is invoked. The .log file contains information pertaining to the failed spotweld elements.
Contents of Spotweld Log File
- The date and time of execution.
 - Weld node or point IDs with their coordinates.
 - Number of layers being welded (2T/3T/4T).
 - HyperMesh component IDs being welded in the case of welds created from macros.
 - Reason for failure.
 - In case of welds that are created but not normal to the shell elements, the orientation (angle) of the welds with respect to the shell element plane is also printed. The angular tolerance specified is (+/-) 5 degrees.
 - When welds are created using macros a message is printed specifying any 3T to 2T or 4T to 3T/2T conversions with point ID and location.
File Format
List of Failed/Angular Welds with Point IDs and location on 04-05-2001 at 14:14:45.
HM_Point#            2T           X           Y           Z           HM Component Ids
       26 2   2193.3940    496.5730   1454.4740       20101       20106    No components found within the tolerance at this location
       27 2   2164.3080    459.9280   1454.9820       20101       20106    Only one component found to weld within the tolerance at this location
                Figure 1. Welds Created from MWF through Macros in Mesh PageList of Failed/Angular Welds with Node IDs and location on 04-05-2001 at 14:28:47.
    Node#           X           Y           Z
       25     10.0000      0.0000      0.5000 Only one component found to weld within the tolerance at this location
       27      5.0000       0.0000      0.5000 Only one component found to weld within the tolerance at this location
       29     1.2000        0.1500      0.7000 Created at an angle     7.0942
                Figure 2. Welds Created from Spotweld Panel
