PARAM, BUSHSTIF
Bulk Data Entry Specifies a value to replace large stiffness values (>1.0E+07) input in field K of the PBUSH Bulk Data Entry.
This parameter can accept two arguments. If only one argument is specified, the same value is used for the second argument.
PARAM, BUSHSTIF, <BUSHSTIFT>, <BUSHSTIFR>
| Parameter | Values | Description |
| BUSHSTIFT | <Real Number ≥
0.0> No default |
This
parameter controls the value of field K in the
PBUSH property entries.
| BUSHSTIFR | <Real Number ≥
0.0> Default = <BUSHSTIFT> |
- Any value on the field K on the PBUSH entry which exceeds BUSHSTIFT or BUSHSTIFR, respectively will be replaced by BUSHSTIFT or BUSHSTIFR.
- Either BUSHSTIFT or BUSHSTIFR (or both) can be set to 0.0. This will disable stiffness control for the corresponding translational or rotational stiffnesses.
- Defaults:
- If BUSHSTIFT is input without specifying a value, then OptiStruct will error out (no default). The default for BUSHSTIFR is BUSHSTIFT.
- If PARAM, BUSHSTIF is not included in the deck, the stiffness value (field K) is not replaced regardless of its value (no stiffness control).
- This parameter applies, in a similar fashion, to the PBUSH1D Rod-type Spring-and-Damper property as well (using BUSHSTIFT).
- This parameter cannot be used to modify the values specified on PBUSHFX Bulk Data Entries.
