PARAM, EXCEXB
Bulk Data Entry Controls the output of the AVL/EXCITE .exb file directly from OptiStruct.
| Parameter | Arguments | Description |
| EXCEXB | TYPE | Defaults If this
parameter is included in the input file, but no value is
provided, then the default value is GMOT.
| RECOV |
- The .exb file contains the connection and interior GRID information, reduced mass, stiffness, and damping matrices, lumped mass matrix of the full system, eigenvalues and eigenvectors of the reduced system, recovery matrix for the interior point displacements, and the inertial invariants.
- DISP = NONE is the default in the generation run, if PARAM, EXCEXB is used. Therefore, if result recovery matrices are required in the .exb file, the corresponding DISP=ALL/<SID> should be added in the EXB generation run.
