PARAM, LFREQH3D
Bulk Data Entry This parameter can be used to request only the modes (structural or coupled) that satisfy the lower bound of frequency, for H3D output.
| Parameter | Values | Description |
| LFREQH3D | <Real> (Hertz) No default (See Comment 3) |
Modes with frequencies below this value are not output in the H3D file. |
- This parameter only applies to H3D output and does not affect the calculations during the simulation.
- This parameter works for complex eigenvalue and normal mode analysis, but only for the structural modes or coupled modes.
- If PARAM, LFREQH3D is used without specifying a value, the simulation will error out.
