PARAM, OPTI
Bulk Data Entry This parameter can be used to activate the new OPTI format, which is enhanced with labels for improved readability.
Parameter | Values | Description |
OPTI | <NEW, OLD> |
- The older/existing OPTI format is still available, and the new format is an addition, only for certain analysis types and output requests. For details on OPTI format, refer to OUTPUT, OPTI in the Reference Guide.
- The following is a comparison of the
old and new OPTI formats using ELFORCE
(.force) as an example. The new format has improved
readability.
Figure 1. Old OPTI format (.force file)
Figure 2. New OPTI format (.force file) - Following is a summary of results and
analysis types for which the new OPTI format is supported.
- Node based results:
Result Type Analysis Types DISPLACEMENT Linear Static, Normal modes, Linear buckling analysis. DISPLACEMENT Frequency response analysis (Direct and Modal) in REAL/IMAG or MAG/PHASE formats. VELOCITY ACCELERATION SPCFORCE Linear Static, Frequency response analysis (Direct and Modal) *. MPCFORCE - Element based results:
Elements Linear Static Analysis Normal Modes Analysis Frequency Response Analysis (Direct and Modal) Response Spectrum Analysis CELAS1, CELAS2 ELFORCE, STRESS, STRAIN ELFORCE, STRESS, STRAIN ELFORCE, STRESS, STRAIN STRESS, STRAIN CROD CBAR CWELD STRESS, STRAIN CGAP ELFORCE, STRESS, STRAIN CSHEAR CFAST CBUSH Shells (CTRIA3, CTRIA6, CQUAD4, CQUAD8) Solids (CHEXA, CPENTA, CTETRA, CPYRA) STRESS, STRAIN STRESS, STRAIN STRESS, STRAIN Axisymmetric Elements (CTAXI3, CTAXI4, CQAXI4, CQAXI8) Plane Strain Elements (CTPSTN3, CTPSTN6, CQPSTN4, CQPSTN8)
