PARAM, VMMASS
Bulk Data Entry Used with MFLUID and PARAM,GRDPNT.
| Parameter | Values | Description |
| VMMASS | <YES, NO> |
- MFLUID and PARAM,GRDPNT should be present in the model for this calculation. Grid point weight generation would be printed twice in this case.
- The virtual mass matrix from wetted surface should be calculated with PARAM,VMOPT,1 for PARAM,VMMASS,YES to include virtual mass matrix for grid point weight generation.
