PARAM, PSDPRINC
Bulk Data Entry The PSD/RMS Absolute Maximum Principal Stress for Random Response Analysis is output or not.
| Parameter | Values | Description |
| PSDPRINC | <YES,
NO> Defaults: When the parameter is not present in the deck, then Maximum principal stress is not calculated or output. When the parameter is present in the deck, but no option/value is provided, then the Absolute Maximum Principal stress is calculated and output. |
