PARAM, FFRSLFREQ
Bulk Data Entry Defines a frequency cut-off value in Hertz used to partition the structural system into low frequency and high frequency parts.
| Parameter | Values | Description |
| FFRSLFREQ | <Real> Default = 1.0 |
PARAM,
FFRSLFREQ relates to the FastFRS
interface. It defines a frequency cut-off value in Hertz used to partition the structural system into low frequency and high frequency parts, to improve matrix condition numbers and solution accuracy at a very small computational cost. If the value is defined as 0.0, then FastFRS will set FFRSLFREQ to 1.0. For more details, refer to FastFRS (Fast Frequency Response Solver) in the User Guide. |
