PARAM, TABS
Bulk Data Entry Converts units of the temperature input (Fahrenheit or Celsius) to the absolute temperature (Degrees Kelvin).
Parameter Values Description
TABS < Real >
Default = 0.0
Absolute temperature scale.
If the temperature input is in Celsius, then PARAM,TABS,273.16 should be used.
If the temperature input is in Fahrenheit, then PARAM,TABS,459.69 should be used.
