Bulk Data Entry The optimization process involving nonlinear
        analysis, in the subsequent optimization iteration the solution of the nonlinear
        problem.
                            | Parameter | Values | Description |
                            | NLINISOL | <YES,
                                    NO> |
                                        YES (Default)The optimization process involving nonlinear analysis,
                                            the nonlinear problem will start, when feasible, from
                                            the converged nonlinear solution of the previous
                                            optimization iteration (instead of repeating the entire
                                            incremental nonlinear process). This can save
                                            computational time.NOThe optimization process involving nonlinear solutions,
                                            nonlinear analysis is always repeated from the
                                            beginning. The entire incremental nonlinear process is
                                            conducted for the analysis. |
                - This re-using of the previous converged solution is only supported when
                    the nonlinear solution is not path-dependent.
