PARAM, FFRSMEM
Bulk Data Entry Defines the amount of memory in Gigabytes to be used by the external FastFRS modal equation solver.
| Parameter | Values | Description |
| FFRSMEM | <Real> Default = Memory used by OptiStruct for a particular run. |
This parameter is only
valid for FastFRS versions 2 and higher. For more details, refer to FastFRS (Fast Frequency Response Solver) in the User Guide. |
- If this parameter is not set, FastFRS will use the amount of memory that OptiStruct is using for the run.
- If the environment variable FFRS_MEM is set, it will override the value set using PARAM, FFRSMEM.
- OptiStruct and FastFRS can be run with different allocations of memory. For example, OptiStruct can be run with 10.0 Gigabytes and FastFRS with 20.0 Gigabytes in the same run.
- This parameter is only valid when PARAM, FFRS is set to YES.
- The minimum FFRSMEM memory value allowed is equal to 1 GB. If a value lower than 1 GB is specified, it is automatically reset to 1 GB.
