PARAM, IMPLOUT
Bulk Data Entry On-the-fly incremental results of nonlinear implicit (static and transient) analysis.
| Parameter | Values | Description |
| IMPLOUT | <YES, NO, ONLY> |
- Results are output on-the-fly in
the *_impl.h3d file, if:
- PARAM,IMPLOUT,YES/ONLY is defined in the model in conjunction with NLOUT Subcase/Bulk Data Entries; or,
- Results specific output on-the-fly is activated. For example: STRESS(NLOUT=<ID>).
- PARAM,IMPLOUT,YES is not required in the case result-specific NLOUT is selected directly from the corresponding results cards (for example, if STRESS(NLOUT=<ID>) is specified). In such cases, the _impl.h3d results file is output for any output which is identified with results specific NLOUT request.
- Generally, this parameter is applicable to small and large displacement nonlinear implicit (static and transient) analysis. For specific details on supported result types, refer to _impl.h3d file.
