OptiStruct Panel
Use the OptiStruct panel to execute an OptiStruct run on your desktop.
The OptiStruct panel eliminates the need to export the input file, to use the Solver panel to execute the job, and to select the results file for post-processing. There is also a HyperView button in the panel that will launch a session of HyperView with the results of your OptiStruct run.
The exported file can contain all or only the displayed model information.
The screen output is automatically set to SCREEN, OUT. This displays the OptiStruct output to the DOS and UNIX window, respectively.
Panel Option
| Option | Action |
| input file: | Navigate to the desired input file. |
| export options | Select a method for
exporting data to the input file before executing an OptiStruct run.
| run options | Select a run option
run.
| memory options | Specify the memory
limit, and decide whether or not to run an in-core or
out-of-core solution depends. The memory default can be changed using the system setting (SYSSETTING) option OS_RAM. You can assign a different memory limit for an individual run by entering a value for memory in upper limit in Mb= or by defining the -len option in the run script. |
| include connectors | Include predefined connectors in the output file. |
| options: | Specify any additional options to write to the solver. |
Command Buttons
| Button | Action |
| Save as | Choose the run location and provide the filename for the OptiStruct input file. |
| OptiStruct | Automatically perform
the following procedures:
| HyperView | Launch a new session of HyperView and load the resulting .mvw file from the OptiStruct run. (Specifically this loads the .mvw file corresponding to the filename in the input file: field). |
| view .out | View the .out file after a run has been submitted. |
