Component Collectors Panel
Use the Component collectors panel to create and update components.
Components act as containers for mesh elements, connectors, or geometry entities; mesh and geometry must be contained within a component, and components can be grouped into assemblies. For example, in a model of a car you might have the lines, surfaces, and so on of the hood panel grouped into a component, which in turn can be grouped along with components for the front quarter-panels, bumper, and so on, into a "front-end" assembly.
Create Subpanel
| Option | Action |
| comp name | Specify a name for the new collector, or click to select an existing collector. |
| color | Select a color for the entity. |
| card image |
Select a card image.
| property |
| material |
Update Subpanel
| Option | Action |
| comp | Select an existing collectors. |
| card image |
| property |
| material |
Assign Subpanel
| Option | Action |
| comps | Select the components to which properties or materials will be assigned. |
| property = / material = | Select the properties or materials to assign to the selected components. The options available may vary depending on the current solver profile. |
Command Buttons
| Button | Action |
| create | Create the new component. |
| create/edit | Create the collector and immediately edit its card image. |
| create prop | When updating a component, in order to assign a property to the component you must also click create prop. |
| create mat | When updating a component, in order to assign a material to the component you must also click create mat. |
| update | Update the selected components with the specified color, card image, properties or materials. |
| update/edit | Update the collector and immediately edit its card image. |
| reset | Clear all card images from the selected components. |
| assign | Assign the selected materials or properties to the chosen components. |
| unassign | Clear the selected materials or properties from the chosen components. |
| reject | Undo an assignment. |
| return | Exit the panel. |
