Sensors Panel
Use the Sensors panel to create and edit modify sensors.
You can create sensors specific to the solver and modify the type and the fields.
This function requires a template file.
Panel Options
| Option | Action |
| name = | Specify a name when creating a new sensor, or click to select an existing sensor to edit. |
| creation method: | Click card image = to select the desired card image. |
Command Buttons
| Button | Action |
| create | Create the new sensor using the specified name and card image. |
| create/edit | Create the new sensor using the specified name and card image, then open the card image in edit mode. |
| edit | Change an existing sensor to use the specified card image. |
| load | Load the specified card image. |
| load/edit | Load the specified card image and open it in edit mode. |
| return | Exit the panel. |
