Vector Collectors Panel
Use the Vectors Collectors panel to create and update vector collectors.
Vector collectors contain vectors which can then be used to define loads or transformations.
Create Subpanel
| Option | Action |
| vectorcol name | Specify a name for the vector collector. |
| color | Select a color for the entity. |
| card image |
Select a card image.
Update Subpanel
| Option | Action |
| card image |
Command Buttons
| Button | Action |
| create | Create the vector collector. |
| update | Change the card image of the selected cards. |
| update/edit | Change the card image and edit the specific details as if you were creating a new vector collector. |
| return | Exit the panel. |
