Grid Attribs Panel
Use the Grid Attributes panel to edit the grid line information contained in a plot.
Grid lines in a plot can be thick or thin, solid or dotted, and can be dense or fine, based on the increments you specify.
Panel Options
| Option | Action |
| plot = | Select a plot. |
| plots (collector) | Select the desired
plots from the modeling window. This is an alternative to using the plot= input. |
| thin lines / thick lines | Choose to use thin or thick lines for the plot. Thick lines are more visible on high-resolution displays. |
| (line option switch) | Choose a design pattern for lines. |
| grid color | Pick a color to draw the grid lines in the plot. |
| margin= | Specify the width of the margins around the plot. |
Command Buttons
| Button | Action |
| update | Update the selected plot(s) to use the current settings. |
| find curves | Select a plot and determine the minimum and maximum values necessary to display all the curves on that plot. The window is then set to that size. |
| circle zoom | Zoom in on an area of your plot. |
| zoom out | Zoom out from a plot. |
