Order Change Panel
Use the Order Change panel to change element order.
Use the Order Change panel to change a group of elements from second order elements to first order elements, or vice versa.
Change to 1st Subpanel
| Option | Action |
| elems | Select the elements to change. |
Change to 2nd Subpanel
| Option | Action |
| midside nodes at extract midpoint / midside nodes projected to surfaces | Choose whether to place the mid-side nodes at the midpoint of the element edge or projected to surfaces associated with the elements. |
| use inferred surface if no geometry exists | Ensure the projection even if there is no underlying geometry when projecting mid-side nodes to a surface. |
Command Buttons
| Button | Action |
| change order | Perform the change. |
| reject | Undo the mos recent change of element order. |
| return | Exit the panel. |
