Load Collectors Panel
Use the Load Collectors panel to create and organize load collectors in your model.
Create Subpanel
| Option | Action |
| loadcol name = | Specify a name for a new collector, or click to select an existing load collectors. |
| color | Select a color for the collector. |
| card image = / no card image / same as |
Update Subpanel
| Option | Action |
| loadcols | Select the load collector to edit. |
Command Buttons
| Button | Action |
| create | Create the collector. |
| create/edit | Create the collector and open the card editor in edit mode. |
| update | Update the selected collector to use the specified color and card image settings. |
| update/edit | Update the selected collector to use the specified color and card image settings, and open the card editor in edit mode. |
| reset | Undo any changes made
to the collector. Note: This will only work as long
as you do not exit the panel. Once you leave the panel, the
changes become permanent.
| return | Exit the panel. |
