Topology Panel
Use the Topology panel to define design domains for topology optimization.
Create Subpanel
| Option | Action |
| desvar | Specify a name for the design variable. |
| props | Select one or more properties of the selected type. |
| type | Select a property type. |
| base thickness | Choose to use the
default base thickness of 0.0 or specify a non-zero value for
the base thickness. A component's total thickness is the same as the thickness given in its PSHELL card. Note: Available when type is set to
PSHELL.
Update Subpanel
| Option | Action |
PSHELL.
Parameters Subpanel
| Option | Action |
| minmemb off / mindim = | Specify a value for the minimum member size control, or toggle the switch to off. |
| maxmemb off / maxmemb | Specify a value for the maximum member size control, or toggle the switch to off. |
| stress constraint | Specify a value for the stress constraint, or toggle the switch to none. |
| fatigue constraint | Choose none, damage < or life >. |
| mesh type | Specify a minimum
dimensions value smaller than the recommended size of 3 times
average element length by enabling the mesh type checkbox and
select aligned. This defines your mesh as being rectilinear and generally aligned in a single direction. |
Draw Subpanel
| Option | Action |
| draw type | Select none, single or split. |
Extrusion Subpanel
| Option | Action |
| extrusion type | Select none, no twist or twist. |
| primary path | Specify the direction of the extrusion. |
| secondary path | Specify how the extrusion is twisted. |
Pattern Grouping Subpanel
| Option | Action |
| pattern type | Select a pattern type. |
Pattern Repetition Subpanel
| Option | Action |
| desvar | Specify a name for the design variable |
| main / secondary / none | Select whether you are establishing a main coordinate system, a secondary design variable, or neither. |
| system /coordinates | Choose to manually enter the values for the coordinate system, or to graphically select the system. |
| global system / local system | Select a reference coordinate system. |
| anchor | Select the anchor node. |
Command Buttons
| Button | Action |
| create | Create the design variable. |
| reject | Revert the most recent changes. |
| review | Review the load in the graphic area. |
| update | Update the load with the most recent changes. |
| return | Exit the panel. |
