Window Panel
Use the Window panel to control xy plot window size and placement.
Panel Options
| Option | Action |
| color override | Override the currently assigned curve colors. |
| display legend | Display the legend. |
| display simulation title | Control the display of the simulation title. |
| plot | Select the plot to edit. |
| resize | Resize a window by selecting a corner inside the window of the plot, holding down the mouse button, and moving the mouse. |
| move | Move a window by selecting a point inside the window of an xy plot to be relocated, holding down the mouse button, and dragging the window to its new position. |
| pop | Bring a window forward to the front of a stack of windows. |
| push | Place a window on the bottom of a stack of windows. |
| stack | Stack the windows in the upper corner of the screen. This function resizes the windows during the process of stacking. |
| unstack | Subdivide the screen and place each displayed window in one of these subdivisions. After this function is complete, the xy plots cover the graphics region of the screen. |
| expand | Enlarge a selected xy plot so that it covers the entire graphics region of the screen. |
| find curves | Determine the minimum and maximum values necessary to display all the curves on that plot. The plot ranges are set to that range. |
| circle zoom | Zoom in on an area of your xy plot. |
| move legend | Relocate the legend. |
