NSM Panel
Use the NSM panel to add non-structural mass entities to a model, or modify existing ones.
Non-structural mass entities can also be realized from the connector module's Apply Mass panel.
The non-structural mass set combination card is supported as a specific load collector with the NSMADD card image. The case control NSM= selector is supported as a control card and is flexible to allow either single NSM or NSMADD references.
HyperWorks directly supports the bulk data cards NSM1 and NSML1. NSM and NSML cards are converted to NSM1 and NSML1 respectively.
Since HyperWorks does not allow multiple NSM cards to have the same SID, when importing it will renumber and create the equivalent NSMADD cards. In addition, HyperWorks will group similar cards to reduce output.
HyperWorks will only export NSM1 and NSML1 bulk data cards.
Create Subpanel
| Option | Action |
| name = | Specify a name for the new NSM. |
| type= | Select a NSM type.
| color | Select a color for the entity. |
| elems/props | Select whether the NSM
will be applied to elements or properties, then select the
desired elems or props. Note: Only available for the OptiStruct solver
interface.
| by entity / all |
Note: Only available for the Nastran
solver interface.
| mass = | Specify the mass value for the NSM. |
Update Subpanel
| Option | Action |
| name = | Select an existing NSM entity that you want to update. |
interface.
| by entity / all |
solver interface.
Command Buttons
| Button | Action |
| create | Create the new NSM entity. |
| update | Update the selected NSM entity to use the current input details. |
| review | Once an nsm entity
exists, type its name into the name = field on either of the
Create or Update subpanels, and then click
review. The elements or properties
that define the nsm are temporarily highlighted. While in review mode on the Update subpanel, you can change the selection of entities by any standard means (clicking entities, using the advanced entity selection menu, and so on) and save the changes by clicking update. This clears the review mode, but if you enter review mode once again the new selection of entities will display. |
| card edit | Edit the card image of the selected entities. |
| return | Exit the panel. |
