Integrate Panel
Use the Integrate panel to obtain the area under a curve. The area under the curve that has been integrated is shaded and the total area, based on the calculation, is given.
Panel Options
| Option | Action |
| plot = | Click the button or text box to display a list of plots in the model, then select the desired plot. |
| curve = | Click the button or text box to display a list of curves in the model, then select the desired curve. |
| from: x = | The starting point on the curve for the area you wish to calculate. Integration will be calculated between this point and to: x=. |
| to: x = | The ending point on the curve for the area you wish to calculate. Integration will be calculated between this point and from: x=. |
| area = | This read-only field displays the total area calculated under the curve between the from: x = and to: x = points. |
| avg height = | This read-only field displays the average height of the curve between the from: x = and to: x = points. |
Command Buttons
| Button | Action |
| integrate | Perform the calculation on the selected curve between the specified points. |
| return | Exit the panel. |
