Query Curves Panel
Use the Query Curves panel to determine the x and y values of points in a curve on a plot.
Panel Options
| Option | Action |
| plot = | Select the desired plot. |
| curve = | Select the desired plot from a list of curves in the selected plot. |
| title = | Displays the title of the selected plot. |
| x = | Click a point on the curve to display it X value in this read-only field. |
| y = | Click a point on the curve to display its Y value in this read-only field. |
| points = | Displays the number of points on the selected curve. |
Command Buttons
| Button | Action |
| position | Calculate the translations and rotations necessary to map the from: nodes to the to: nodes, and then apply these translations and rotations to the selected entities. |
| reject | Undo the transformation and return the selected entities to their original positions. |
| return | Finalize the transformation and exit the Position panel. |
