Temp Nodes Panel
Use the Temp Nodes panel to control which nodes are on the temporary node mark.
Since all nodes not currently referenced in the model are deleted, the temporary node mark is provided as a holding area to save the nodes you are not currently using. Those nodes are saved as long as they are in the temporary node mark.
Panel Options
| Option | Action |
| nodes selector | Select the nodes that you want placed on the temporary node mark. |
Command Buttons
| Button | Action |
| add | Add the selected nodes. |
| clear | Remove the selected
nodes from the temporary node mark. When nodes are removed from the temporary node mark, the node is deleted if it is not attached to a structural element, and is not used by a card in the database. |
| clear all | Remove all nodes from the temporary node mark. |
| return | Exit the panel. |
