Super Elems Panel
Use the Super Elems panel to assign nodes to a super element set. You can also display the nodes that belong to a super element.
All of the nodes belonging to the super element are displayed as long as you remain in the Super Elems panel. This includes nodes not associated with elements currently displayed.
All nodes initially belong to super element 0.
Panel Options
| Option | Action |
| node selector | Select the nodes to assign. |
| element id | Specify the ID of the super element. |
Command Buttons
| Button | Action |
| set | Assign the nodes to the super element selected. |
| review | Display the super element whose id was entered in the element id field. |
| return | Exit the panel |
