Grid Labels Panel
Use the Grid Labels panel to edit the grid labels on the x and y axes of a plot. It allows you to change the font and color of the grid tic marks.
In this panal you can select the format of the grid labels: automatically calculated, exponential, or a user-specified, fixed decimal point. You can also specify the level of precision to be used in the grid labels.
Panel Options
| Option | Action |
| plot = | Select a plot. |
| plots (collector) | Select the desired
plots from the modeling window. This is an alternative to using the plot= input. |
| tic color | Pick a color to draw the labels. |
| (font option switch) | Choose the font to display labels in. |
| x: auto / fixed / exponential | Select the scale factor for the X axis. |
| y: auto / fixed / exponential | Select the scale factor for the X axis. |
| precision = | Specify the number of decimal places to use in the grid label. |
Command Buttons
| Button | Action |
| update | Update the selected plot(s) to use the current settings. |
| return | Exit the panel. |
