Bodies Panel
Use the Bodies panel to create, review, and update group entities.
Create Subpanel
| Option | Action |
| body | Enter a name for the new body, or double-click body= and select an existing body. |
| type |
Select a body type.
| body color | Select a color for the new body. |
| properties: props | Select properties referenced by elements for inclusion in the body using the props selector. |
| rigids: elems | Select rigid (RBAR, RROD, RBE2, RBE3) or mass (CONM2) elements for inclusion in the body using the elems selector. |
| free nodes: nodes | Select additional free nodes for inclusion in the body using the nodes selector. |
| CMS Method | Select the type of Component Mode Synthesis to perform while creating the flexible body. |
| frequency upper bound |
Use a default upper boundary for the frequency or manually
enter an upper bound.
Note: You only need to define frequency upper bound or number
of modes, not both.
| number of modes |
Use a default number of modes or manually enter a desired
number of modes.
Note: You only need to define frequency upper bound or number of
modes, not both.
Update Subpanel
| Option | Action |
| type |
Select a body type.
of modes, not both.
| number of modes |
number of modes.
modes, not both.
Parameters Subpanel
| Option | Action |
| flex nodes | Add degrees of freedom to nodes and/or remove interface nodes
from the body definition. Add degrees of freedom to nodes by first selecting nodes using the flex nodes selector, then select dof checkboxes accordingly and click add. Remove interface nodes from the body definition by first selecting nodes using the flex nodes selector, then click remove. All degrees of freedom will be cleared. |
| dof1-dof6 | Select degrees of freedom for the nodes selected using the flex nodes selector. |
| do not determine interface nodes automatically | Prevent automatic determination of flexible body interface nodes so that you can specify them manually. |
| damping | Use the default damping for flexible bodies or manually enter a critical desired ratio. |
| mass | Selected body's total mass. This overrides computation based on material and property information that would otherwise occur. |
| lxx, lyy, lzz, lxy, lxz, lyz | Explicitly define the selected body’s values. This overrides computation based on material and property information that would otherwise occur. |
| global system / local system | Select the coordinate system to which the defined moments of inertia are related. |
| COG | Choose the location of the center of gravity by selecting a grid point in the display, or double-click COG to manually enter the coordinates. |
Command Buttons
| Button | Action |
| create | Create the body. |
| review | Click review after selecting the body
to enter review mode. In this mode the body’s constituent
entities display in red, while selected flex-nodes of a flexible
body display in blue. The remaining model is drawn in
gray. This review mode is a temporary graphics mode; you
can exit out of review mode by clicking
review again or leaving the
panel. While in review mode, use review opts to customize
the graphical review of the bodies.
| card image | Open the card image for the selected body. |
| update | Update the selected body definition with your new settings. |
| update color | Update only the body color. All other settings remain unchanged. |
| return | Exit the panel. |
