Dconstraints Panel
Use the Dconstraints panel to create constraints for an optimization problem.
Panel Options
| Option | Action |
| constraint | Select the constraint. |
| lower bound | Enter the value for the lower bound. |
| upper bound | Enter the value for the upper bound. |
| response | Select the response to be constrained. |
