Multibody Collectors Panel
Use the Multibody Collectors panel to generate new multibody collectors.
Multibodies are jointed bodies made up of multiple parts, and are often used to simulate crash test dummies and similar objects during crash analysis.
Create Subpanel
| Option | Action |
| multibody name = | Specify a load collector name. |
| color | Select a color for the entity. |
| card image / no card image / same as |
Select a card image.
| center of gravity: N1 | Select a node in the model to specify the multibody collector's center of gravity. |
| duplicate this system / use this system / use body's local system | Select a method for
assigning a coordinate system to the multibody collector.
Update Subpanel
| Option | Action |
| multibodies | Select the multibodies to modify. |
| card image = / no card image / same as |
Command Buttons
| Button | Action |
| create | Create the new collector. |
| create/edit | Create the new collector and open its associated card image in edit mode. |
| update | Update the selected collectors to use the current input settings. |
| update/edit | Update the selected collectors to use the current input settings, then open their associated card image in edit mode. |
| reset | Reset the selected collectors to their previous input values. |
| return | Exit the panel. |
