Global Panel
Use the Global panel to control global parameters that are accessed by several different panels. These parameters remain constant until changed. It also controls which components or collectors are active. Any entities you create are stored in the active collectors. Finally, you can use this panel to specify which template file you want to use. (Template files must first be created.)
Location: Only accessible in the panel area by pressing "g" on the keyboard.
Panel Options
| Option | Action |
| template file | Specify the path and filename of the desired file. |
| results file | Click browse, then navigate to and select the desired file. |
| pg1 / pg2 | Choose between visible sets of collectors. |
| current collectors: | Click each button, then select an existing collector to make current. |
Command Buttons
| Button | Action |
| load | Open a file browser to navigate to and select the desired template file. |
| return | Exit the panel. |
