Use the Rename panel to change the name of a specific collector or to rename types of
collectors to their respective ID with an optional prefix.
Analysis page > Safety module
Note: A different version of the Rename
panel exists in many modules, such as the Safety module or the Optimization
module. These alternate panels are analogous to the main Rename panel, except
that they only enable you to rename entities appropriate to the module. In
contrast, the main Rename panel lets you rename any entity at all.
Individually Subpanel
| Option |
Action |
| entity switch |
Select the type of
entity to rename. |
| original name
Click to select an
existing collector. |
| new name = |
Specify a new name for
the collector. |
All By ID Subpanel
| Option |
Action |
| (entity
switch) |
Select the type of
entity to rename. |
| prefix |
This prefix, plus a
number, will become the new name of every collector of the
chosen type. For example: if you specify
part as the prefix, then all
components of the chosen type will be renamed to part1, part2,
and so on. |
Command Buttons
| Button |
Action |
| rename |
Rename the selected
entities according to the input settings. |
| return |
Exit the
panel. |
