Element Cleanup Panel
Use the Element Cleanup panel to perform automatic cleanup of 2D elements based on the element quality criteria from the Quality Index panel or a separate criteria file.
Element Cleanup Process
By default, all associated geometry will be utilized as part of the cleanup process, if any exists. If this is not desired, you must disassociate the FE from the geometry.
The cleanup process is automated, but the panel includes many options to affect how it behaves and the types of problems it will attempt to clean up.
Panel Options
| Option | Action |
| anchor nodes | Select anchor nodes to preserve during the clean-up process. |
| consider only affected elems | Use only failed elements during the clean-up process. |
| Divide quads into trias (Quality Correction tab) | Specify if quads are allowed to split into trias to correct warpage. |
| elems | Select elements to perform clean-up. |
| elems failing QI check | Limit other options by examining whether or not the resulting elements would fail your QI criteria. For example, using tria reduction with this option activated might result in fewer trias being removed, but better overall mesh quality. |
| Feature angle (Quality Correction tab) | Define the feature and vertex angle used for auto generating 1D features, when required. |
| feature edges | Select feature edges (node paths) to preserve during the clean-up process. |
| keep connectivity with 1D/3D | 2D element edges that are shared with 1D/3D element edges before cleanup should be preserved during cleanup. |
| Move across free edges <= (Quality Correction tab) | Define the allowable node movement for nodes on free edges to correct minimum size. |
| Move across non-manifold edges <= (Quality Correction tab) | Define the allowable node movement for nodes on non-manifold edges to correct minimum size. |
| Move across shared edges <= (Quality Correction tab) | Define the allowable node movement for nodes on shared edges to correct minimum size. |
| Offset from surfaces <= (Quality Correction tab) | Define the allowable node movement normal to surfaces to correct warpage. |
| reduce tria elems | Attempt to combine trias into quads. If you also enable elems failing QI check, the tria reduction will be tempered by the constraints on the resulting quads. |
| use adjacent elem layers | Define the number of
adjacent layers to include for failed elements. Note: Only
available when consider only affected elems is
enabled.
Command Buttons
| Button | Action |
| edit criteria | Open the Criteria File Editor, from which you can define the quality index (QI) mesh criteria. |
| edit parameters | Open the Parameters
File Editor, from which you can define the parameters that
determine how far nodes can move away from edges or normal to
the surface. The following parameters are explicitly
considered:
Note: Associativity is not maintained after
nodes are moved away from the geometry, therefore
performing element clean-up consecutively may return
different results.
| cleanup | Perform the cleanup on the selected elements, using the currently specified settings. |
| reject | Revert the most recent cleanup operation, provided that you have not left the panel in the meantime. |
| review | Isolate the elements that adhere to the settings defined in the panel, Criteria File Editor, and Parameters File Editor. |
| return | Exit the panel. |
