Torus Panel
Use the Torus panel to create an analytic, toroidal surface and/or mesh.
- normal axis
- The vector created by the center node to the normal vector node.
- major axis
- The vector created by the center node to the major vector node.
The normal vector, center, and major vector should form a 90 degree angle. If they do not, the major axis is calculated at 90 degrees using the normal axis.
For partial toroidal surfaces, zero degrees on the minor radius starts on the major axis and spins inward toward the center. Zero degrees on the major radius also starts on the major axis.
In the Three Points subpanel, the major radius is the distance between the major center and the minor center. The minor radius is the distance between the minor center and the minor radius.
Full Torus Subpanel
![]() Figure 1. Points Selected |
![]() Figure 2. Surface Created |
| Option | Action |
| center | Select the nodes that represent the center point. |
| normal vector | Select the nodes that represent the normal vector point. |
| surface behavior |
| minor / major radius | Specify a value. |
User Controlled Subpanel
![]() Figure 3. Points Selected |
![]() Figure 4. Surface Created |
| Option | Action |
| major vector | Select the nodes that represent the major vector point. |
| surface behavior |
| minor / major radius | Specify a value for each. |
| minor start / end | Specify a value. |
| major start / end | Specify a value. |
Three Points Subpanel
![]() Figure 5. Points Selected |
![]() Figure 6. Surface Created |
| Option | Action |
| major center | Select the nodes that represent the major center point. |
| minor center | Select the nodes that represent the minor center point. |
| minor radius | Select the nodes that represent the minor radius point. |
| surface behavior |
Command Buttons
| Button | Action |
| create | Create the toroidal surface. |
| reject | Reject the changes. |
| return | Exit the panel. |
