Use the ALE Setup panel to create and modify input data pertaining to the
Arbitrary-Lagrangian-Eulerian.
Important: Only available in the LS-DYNA solver interface.
Create Subpanel
Use the Create subpanel to create ALE groups.
| Option |
Action |
| name |
Specify a name for the ALE card. |
| type |
Specify a type for the ALE card.
- Type (HyperWorks Card
Image)
- LS-DYNA Keyword
- ConstdLagSolid
- *CONSTRAINED_LAGRANGIAN_IN_SOLID
- InitialGasMix
- *INITIAL_GAS_MIXTURE
- InitialVoid
- *INITIAL_VOID_PSID
- DatabaseFsi
- *DATABASE_FSI
- DatabaseFsiSensor
- *DATABASE_FSI_SENSOR
- BoundAmbEos
- *BOUNDARY_AMBIENT_EOS
- InitVolFractGeo
- *INITIAL_VOLUME_FRACTION_GEOMETRY
- InitialALEMapping
- *INITIAL_ALE_MAPPING
Additional cards related to ALE modeling:
- *SECTION_POINT_SOURCE
(collector/property panel)
(*Element_Solid card image)
| color |
Select a color for the ALE group. |
Add/Update Subpanel
Use the Add/Update subpanel to link entities such as components or a set to the ALE
cards created in the Create subpanel.
| Option |
Action |
| name |
| options |
Use the entity selector to select entities to link to the ALE
card. |
Command Buttons
| Button |
Action |
| create |
Create the ALE card. |
| update |
Update the selected card with the new information. |
| create/edit |
Create the ALE card and immediately open the Card Editor with
the ALE card loaded. |
| review |
Highlight the selected mass element. |
| edit |
Open the Card Editor with the current ALE card
loaded. |
| update color |
Update the ALE card color with the newly selected
color. |
| return |
Exit the panel. |
