Reorder Panel
Use the Reorder panel to change the order of named entities in database.
Changing this order affects the listing in the display and entity selection panels, and the order in which these entities are plotted.
Panel Options
| Option | Action |
| entity selector | Select an entity type, then select the entities that you wish to reorder. |
| sort by: | Choose whether to sort
by the entity name or ID. If you choose neither, the selected entities are moved in the list, but maintain their order relative to each other. |
| move to: | Choose where the entities are positioned in the list (front or back). |
Command Buttons
| Button | Action |
| reorder | Change the order of the selected entities in accordance with the input settings. |
| return | Exit the panel. |
