Ribs Panel
Use the Ribs panel to create and modify simple ribs between two surfaces.
Figure 1. Triangular Rib Terminology
Figure 2. Quadrilateral Rib Terminology
Panel Options
| Option | Action |
| rib type | Choose a rib type.![]() Figure 3. Triangular Shaped Rib ![]() Figure 4. Quadrilateral Shaped Rib |
| profile plane | Define the location
and orientation of the rib. This plane is used as reference
geometry, with respect to which sides of the rib are
constructed. For example, when draft angle is zero, the two side
surfaces of the rib are parallel to this plane. Select a rib profile plane using the plane selector (x,y,z planes, vector or a base node). |
| plane position | Select the rib position from the profile plane (centered, on right or on left). |
| rib start node | Select a rib start node on a surface where the rib will start. You can modify this during the preview. This will give the height of the rib. |
| rib end node | Select a rib end node on a surface where the rib will end. You can modify this during the preview. This will give the length of the triangular rib or the height at the other end of the quadrilateral rib. |
| height and length | Specify the height and length of the triangular rib. |
| height 1 and height 2 | Specify height 1 and height 2 of the quadrilateral rib. Provides heights at both ends for the quadrilateral rib. |
| width | Specify the width of the rib. |
| draft angle | Specify an angle used for the side face inclination. |
Command Buttons
| Button | Action |
| add | Create the geometry if the preview is correct. |
| reject | Reject any changes that were made. |
| return | Exit the panel. |
