MBS Planes Panel
Use the MBS planes panel to create rectangular, planar surfaces for use in multi-body analyses. The created entity is an mbplane.
Create Subpanel
| Option | Action |
| name = | Specify a name for the new joint. |
| color | Select a color for the mbplane. |
| Vertices' coordinates: | Define the dimensions of the plane using the N1, N2, N3 selectors. Click N1, then select a node or temp node in the modeling window. Repeat to select two other non-collinear nodes for N2 and N3. |
| multibody = | Select an existing multibody. |
Update Subpanel
| Option | Action |
| mbplane | Select the mbplane to modify. |
Resize Subpanel
| Option | Action |
| mbplanes | Select the mbplanes to resize. |
| corner 1, corner 2, corner 3 | Move the corners. Selected corners will move in the specified direction for the specified magnitude. |
| direction: | Define the
direction.
| magnitude | Specify the amount of distance to extend each selected corner. |
Permute Subpanel
| Option | Action |
| mbplanes | Select the mbplanes whose possible permutations to cycle through. |
Command Buttons
| Button | Action |
| create | Create the new mbplane entity. |
| reject | Undo the mos recent creation, update, resize, or permutation. Changes become permanent (cannot be rejected) once you leave the MBS Planes panel. |
| update | Update the selected mbplane according to the inputs on the update subpanel. |
| resize + | Resize the selected mbplanes along the specified direction by the positive magnitude. |
| resize - | Resize the selected mbplanes along the specified direction by the negative magnitude. |
| review normals | Display the normal direction of each selected mbplane. |
| flip normals | Reverse the normals of each selected mbplane. |
| permute | Cycle through each possible permutation for the selected mbplanes, swapping plane vertices that affect either the orientation of the plane or the normal direction of the plane. |
| return | Exit the panel. |
