Markers Panel
Use the Markers panel to create, review and update sensor entities.
The sensor entity directly corresponds to the OptiStruct MARKER definition which is used only in Multi-Body Dynamics Analysis.
Create Subpanel
| Option | Action |
| marker name = | Specify a name for the new marker, or double-click to select an existing marker. |
| color: | Select a color for the
marker. Note: Markers are only visible in the Model Browser; markers have no visual
representation in the modeling window.
| location: node | Select a node to define the location of the marker. |
| orientation: system | Select a coordinate system that defines the orientation of the marker. If no system is selected, then the global system is the default. |
| orientation: edit | If the desired coordinate system does not already exist, click edit to open the Systems panel for quick access to create a new one. |
Update Subpanel
| Option | Action |
| markers | Select an existing marker. |
| color | Select a color for the
| orientation: edit | Open the Systems panel to edit a system or create a new one. |
Command Buttons
| Button | Action |
| create | Create a new marker. |
| review | Click
review and select a marker to
visualize. The referenced node and system will highlight. Note: There is no graphical representation for
Markers. The review functionality will allow you to
visualize the node and coordinate system referenced by the
Marker.
| update | Update a marker after changing its location, orientation or color. A new, temporary panel opens, with checkboxes to allow you to select any combination of these characteristics to update. |
| return | Exit the panel |
