True View Panel
Use the True View panel to change the current view of your model based on a model vector or angles.
Panel Options
| Option | Action |
| thetax | Specify the rotation about the x axis |
| thetay | Specify the rotation about the y axis |
| thetaz | Specify the rotation about the z axis |
| N1, N2, N3, B | Select the plane whose normal should be oriented normal to the screen. |
Command Buttons
| Button | Action |
| set angles | Set the view angles to the values entered in the fields. |
| get angles | Place the current view angles in the corresponding fields. |
| true view | Display the true view. |
