Control Cards Panel
Use the Control Cards panel to set job-level, solver specific data.
When the panel opens, a list of available control cards displays. The available control cards are defined in the template file.
- Click each blank (gray) field label to activate an entry field. Entry fields may include buttons that access pop-up menus, text or number fields, or entity selectors.
- In the selected control card click default to return all fields to their default values
- Click reject to clear all entries and start over
- Click return to keep the new card, or abort to cancel without creating it.
Once a card has been edited and left by the return button it will show in green status.
- Gray
- Card does not exist in the database.
- Green
- Card exists in the database.
- Red
- Card exists in the database, but is disabled. In this case it will, but will not be written upon export.
Panel Options
| Option | Action |
| delete | Remove a control card
from the database and then select the card you want to delete.
Only cards with green or red status can be deleted. The card will show gray status after deletion. |
| disable | Select a control card
to remain in the database, but not export. The color status
changes to red. Only enabled data cards can be disabled (those with a green status). |
| enable | Select a control card
that you wish to export the contents. The color status of the
card changes to green. Only disabled data cards can be enabled (those with a red status). |
| next/prev | In case a solver interface has too many control cards to show in one 'page' use next/prev to cycle through them. |
| return | Return to the Analysis page. |
