Review Thickness Tool
Use the Review Thickness tool to review the thickness of surfaces (including midsurfaces) and assign new fixed, uniform thicknesses to surfaces.
| Option | Action |
| assign thickness surfs selector | Select surfaces for which you want to assign a thickness. |
| average thickness | Display the average thickness for selected surfaces. |
| max thickness | Display the maximum thickness for selected surfaces. |
| min thickness | Display the minimum thickness for selected surfaces. |
| new thickness | Specify a thickness value to assign to the selected surfaces. |
| view thickness: surfs selector | Select surfaces for which you want to review the thicknesses of. |
