alefsiprojections
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
alesid
The set ID defining the ALE part(s).
Type: entity
asidtyp
The ALE set ID type.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
birth
The coupling start time.
Type: double
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *ALE_FSI_PROJECTION
death
The coupling end time.
Type: double
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
icorrec
The advection error correction method.
Type: integer
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
inorm
The coupling type.
Type: integer
lagsid
The set ID defining the Lagrangian part(s).
Type: entity
lsidtyp
The Lagrangian set ID type.
Type: integer
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
smmgid
The set ID referring to a group of one or more AMMG IDs.
Type: entity
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
