curves
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - encrypted
 - True if the entity is encrypted, false otherwise.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - linetype
 - The line style used to draw the line.
 - markertype
 - The marker type used to indicate points on the curve.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - numberofpoints
 - The number of points in the curve.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - points
 - A pointer to the points in the curve (pointervalue is curve point).
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - scalex
 - The x scale factor.
 - scaley
 - The y scale factor.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - title
 - The title of the curve.
 - width
 - The width of the curve.
 - xcomp
 - The name of the x request component.
 - xkind
 - The type of source for the x data.
 - xpath
 - The file path and name or math expression for x data.
 - xreq
 - The name of the x request.
 - xtype
 - The type of the x component.
 - ycomp
 - The name of the y request component.
 - ykind
 - The type of source for the y data.
 - ypath
 - The file path and name or math expression for y data.
 - yreq
 - The name of the y request.
 - ytype
 - The type of the y component.
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
