designpoints
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
 - Returns non-zero if the entity is set inactive, 0 otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - attributesmax
 - color
 - The 1-64 color of the entity.
 - color_rgb
 - The RGB color of the entity.
 - config
 - The configuration of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - designpointstrucelemid
 - The ID of the structural property.
 - deviation
 - The magnitude of displacement from the measurement node (stored in the underlying structural property with config 83) to the position of the design point.
 - deviation_x
 - The signed difference between the abscissae of the measurement node (stored in the underlying structural property with config 83) and the position of the design point.
 - deviation_y
 - The signed difference between the ordinates of the measurement node (stored in the underlying structural property with config 83) and the position of the design point.
 - deviation_z
 - The signed difference between the applicates of the measurement node (stored in the underlying structural property with config 83) and the position of the design point.
 - entityids
 - The IDs of the entities.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - num_failed_coords
 - The total number of coordinates of the measurement node based on whether 'deviation_x' or 'deviation_y' or 'deviation_z' is not within either the allowed positive or negative deviation (as applicable).
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - panellength
 - The calculated panel length if the design point contains panel entities.
 - panelradius
 - The calculated panel radius if the design point contains panel entities.
 - panelwidth
 - The calculated panel width if the design point contains panel entities.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - position
 - The coordinates of the location.
 - projectentityids
 - The IDs of the projection entities.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - system
 - The ID of the system.
Version History
2019.1
2020 - Added new data names activesuppressed, color_rgb, name, outputsuppressed, panellength, panelradius, panelwidth and position.
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
2022 Added new data names deviation, deviation_x, deviation_y, deviation_z, internalname, num_failed_coords and solvername. Added new config value 81.
