seatbelts
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
autoupdate
Allows update of control points of the seatbelt segment, when true.
Type: Boolean
belt_nbcomp
The null beam component.
Type: entity
belt1delemsize
The length of 1D seatbelt elements.
Type: double
belttype
The mesh type of the seatbelt entity.
0 - 1D seatbelt elements only
1 - 1D and shell elements
2 - 1D and 2D seatbelt elements
3 - 2D seatbelt elements only
4 - 2D seatbelt and shell elements
5 - Shell elements only
check_belt_nbcomp
Option to create beam elements on belt components for edge-to-edge contact.
Type: Boolean
check_edgetoedge
Option to create edge-to-edge contacts between all seelcted/created beam components.
Type: Boolean
check_remesh_mode
The flag to activate the remesh mode.
Type: Boolean
check_struct_nbcomp
Option to create beam elements on structural components for edge-to-edge contact.
Type: Boolean
check_surftosurf
Option to create contact between seatbelt components and selected structural components.
Type: Boolean
check_wrap_nbcomp
Option to create beam elements on wrao around components for edge-to-edge contact.
Type: Boolean
childrentoseatbelt
The IDs of the children seatbelt segments of the seatbelt system.
Type: entity array
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
commonnode
The ID of the filled end node, used to check segment connectivity.
comp1d
The ID of the component used to fill all 1D elements of the seatbelt system.
Type: entity
comp1d_first
The ID of the start component of the seatbelt segment.
Type: entity
comp1d_second
The ID of the end component of the seatbelt segment.
Type: entity
comp2d
The ID of the component used to fill all 2D shell elements of the seatbelt system.
Type: entity
comp2d4n_first
The ID of the 2D 4N start component of the seatbelt segment.
Type: entity
comp2d4n_second
The ID of the 2D 4N end component of the seatbelt segment.
Type: entity
comps1d
The ID of the 1D components of the seatbelt system.
Type: entity
comps1d_count
The number of 1D components in the seatbelt segment.
comps4n
The ID of the 2D 4N components of the seatbelt system.
Type: entity
comps4n_count
The number of 2D 4N components in the seatbelt segment.
config
The configuration of the entity.
1 - 2D belt (1D and 2D seatbelt elements)
2 - 1D belt
3 - Seatbelt system
4 - 1D and shell elements
5 - 2D seatbelt elements only
6 - 2D seatbelt and shell elements
7 - Shell elements only
contact
The IDs of the contacts in the seatbelt system.
Type: entity array
contact_edgetoedge
The ID of the edge-to-edge contact between all selected/created beam components.
Type: entity
contact_surftosurf
The ID of the contact between seatbelt and selected structural components.
Type: entity
contactcount
The number of contacts in the seatbelt system.
contacttemplate
The IDs of the contact templates of all types.
Type: entity array
createsecondretractor
Allows creation of a second retractor if true.
Type: Boolean
cs_end_count
The number of cross-sections at the end of the segment.
cs_end_list
The list of cross-sections at the end of the segment.
Type: entity array
cs_start_count
The number of cross-sections at the start of the segment.
cs_start_list
The list of cross-sections at the start of the segment.
Type: entity array
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
dummysets
The IDs of the sets of the seatbelt system.
Type: entity array
dummyshellset
The ID of the dummy shell set.
Type: entity
dummysolidset
The ID of the dummy solid set.
Type: entity
elems1d
The IDs of the 1D seatbelt elements.
Type: entity array
elems1d_rbody_id_f
The first 1D rigid body element of the seatbelt segment.
Type: entity
elems1d_rbody_id_l
The last 1D truss element of the seatbelt segment.
Type: entity
elems1d_truss_id_f
Type: entity
elems1d_truss_id_l
The last 1D rigid body element of the seatbelt segment.
Type: entity
elems2d
The IDs of the 2D seatbelt elements.
Type: entity array
elems2d_id_f
The first 2D shell element of the seatbelt.
Type: entity
elems2d_id_l
The last 2D shell element of the seatbelt.
Type: entity
elems2d4n_id_f
The first 2D 4N shell element of the seatbelt.
Type: entity
elems2d4n_id_l
The last 2D 4N shell element of the seatbelt.
Type: entity
elems4n
The IDs of the 2D 4N seatbelt elements.
Type: entity array
endsets
The IDs of the end sets of the seatbelt segment, used to create rigid links.
Type: entity array
endtype
The end type of the seatbelt segment, which indicates if there is a rigid link or tria surface.
existing_nbcomp
The IDs of the existing beam components for edge-to-edge contact.
Type: entity array
extra_struc_comps
The IDs of the extra components required for contact with seatbelt.
Type: entity array
from2dendlength
The number of 2D seatbelt elements needed at the start of the seatbelt.
fromendlength
The length of 1D elements needed at the start of the seatbelt.
Type: double
fromendvector
The end vector at the start of the seatbelt segment.
Type: triple double
from_nodes_1d
The ordered 1D nodes at the start of the seatbelt.
Type: entity array
gap
The offset between the wrap components and the seatbelt.
Type: double
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
isendefault
True if allowed to change the end vectors of the seatbelt, false otherwise.
Type: Boolean
isseatbeltfirstinincludefile
True if the seatbelt is the first include in the file and exports end of data if it is, false otherwise.
Type: Boolean
meshelemsize
The size of the 2D mesh elements.
Type: double
mesh_nodes_2d
The ordered nodes of all 2D elements in the seatbelt.
Type: entity array
meshtype
The type of the 2D mesh elements.
middlevectors
The array of middle vectors at the control points of the seatbelt segment.
Type: triple double array
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
nodeslist
The list of nodes to create the seatbelt.
Type: entity array
orientvectors_count
The number of seatbelt orientation vectors.
orientvectors_x
The x components of the seatbelt orientation vectors.
Type: double array
orientvectors_y
The y components of the seatbelt orientation vectors.
Type: double array
orientvectors_z
The z components of the seatbelt orientation vectors.
Type: double array
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
parentseatbelt
The parent seatbelt system of the seatbelt segment.
Type: entity
penetrationcheck
True if automatic penetration removal is enabled, false otherwise.
Type: Boolean
penetrationcheck
True if remesh/recreation is enabled, false otherwise.
Type: Boolean
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
row_node_count
The number of nodes per row of the 2D seatbelt.
rows
The number of 2D element rows in the seatbelt segment.
seatbeltcontact
True if contact creation is enabled, false otherwise.
Type: Boolean
seatbeltdummymechanismlink
True if the dummy and mechanism are linked with the seatbelt system, false otherwise.
Type: Boolean
seatbelt_seg_f
The first node of the seatbelt segment.
Type: entity
seatbelt_seg_l
The last node of the seatbelt segment.
Type: entity
seatbeltcompcollector
All components created for elements in the seatbelt system.
Type: entity array
seatbeltsystemnodes
All nodes in the seatbelt system in the belt path order.
Type: entity array
seatbeltsystempointprefix
The prefix for names of control points.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
struct_nbcomp
The ID of the created null beam component for structural components.
Type: entity
thickness
The thickness of the seatbelt system.
Type: double
to_nodes_1d
The ordered 1D nodes at the end of the seatbelt.
Type: entity array
to2dendlength
The number of 2D seatbelt elements needed at the end of the seatbelt.
toendlength
The length of 1D elements needed at the end of the seatbelt.
toendvector
The end vector at the end of the seatbelt segment.
Type: triple double
unit_system
The unit system:
0 - mm, ms, kg
1 - mm, s, Mg
updateonthefly
True if allowed to make updates (for example, changing belt type and node list) to the seatbelt segment, false otherwise.
Type: Boolean
width
The width of the seatbelt system.
Type: double
wrap_nbcomp
The ID of the created beam component for wrap components.
Type: entity
Version History
2020
2020.1 - Added new data name solverkeyword.
2021 - Added new data names belt_nbcomp, check_belt_nbcomp, check_edgetoedge, check_struct_nbcomp, check_surftosurf, check_wrap_nbcomp, contact_edgetoedge, contact_surftosurf, existing_nbcomp, extra_struc_comps, extra_struc_comps, struct_nbcomp and wrap_nbcomp.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names check_remesh_mode,from_nodes_1d, internalname, mesh_nodes_2d, row_node_count, solvername, and to_nodes_1d.
