beamsects
The beam section may or may not have any results data available. If the requested data item has not been defined, then the value returned is "-99999.9"
internalname
The internal name of the entity.
Type: string
moduleid
The module ID of the entity.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
results_area
The area of the beamsect.
Type: double
results_centroid0
The local y-coordinate of the centroid of the beamsect.
Type: double
results_centroid1
The local z-coordinate of the centroid of the beamsect.
Type: double
results_coordExt0
The coordinate extent in the y direction.
Type: double
results_coordExt1
The coordinate extent in the z direction.
Type: double
results_coordExtP0
The coordinate extent in y principal coordinates.
Type: double
results_coordExtP1
The coordinate extent in z principal coordinates.
Type: double
results_elasticCenter0
The y-coordinate of the elastic center.
Type: double
results_elasticCenter1
The z-coordinate of the elastic center.
Type: double
results_Emt
The elastic torsion modulus.
Type: double
results_gamma
The warping constant.
Type: double
results_lcentroid0
lyy in centroidal coordinates.
Note: This data name contains an uppercase I (i).
Type: double
results_lcentroid1
lzz in centroidal coordinates.
Type: double
results_lcentroid2
lyz in centroidal coordinates.
Type: double
results_lprincipal0
lv principal moment of inertia.
Type: double
results_lprincipal1
lw principal moment of inertia.
Type: double
results_luser0
lyy in user coordinates.
Type: double
results_luser1
lzz in user coordinates.
Type: double
results_luser2
lyz in user coordinates.
Type: double
results_J
The torsional constant.
Type: double
results_NumberOfCells
The number of cells in the section.
Type: integer
results_Pmt
The plastic torsion modulus.
Type: double
results_PrincipalShear0
The principal shear in the y direction.
Type: double
results_PrincipalShear1
The principal shear in the z direction.
Type: double
results_radiusG
The radius of gyration.
Type: double
results_S0
The Ey elastic section modulus.
Type: double
results_S1
The Ez elastic section modulus.
Type: double
results_shearAngle
The shear angle.
Type: double
results_shearCenter0
The y coordinate of shear center.
Type: double
results_shearCenter1
The z coordinate of shear center.
Type: double
results_shearCenterP0
The y coordinate of shear center in principal coordinates.
Type: double
results_shearCenterP1
The z coordinate of shear center in principal coordinates.
Type: double
results_ShearDeform0
The shear deformation coefficient alpha-yy.
Type: double
results_ShearDeform1
The shear deformation coefficient alpha-zz.
Type: double
results_ShearDeform2
The shear deformation coefficient alpha-yz.
Type: double
results_shearStiff0
The shear stiffness factor kyy.
Type: double
results_shearStiff1
The shear stiffness factor kzz.
Type: double
results_shearStiff2
The shear stiffness factor kyz.
Type: double
results_SP0
Ey in principal coordinates.
Type: double
results_SP1
Ez in principal coordinates.
Type: double
results_theta
The principal angle.
Type: double
results_torsionCoeff0
The torsional coefficient in the y direction.
Type: double
results_torsionCoeff1
The torsional coefficient in the z direction.
Type: double
results_Z0
The plastic section modulus Py.
Type: double
results_Z1
The plastic section modulus Pz.
Type: double
results_ZP0
The plastic section modulus Py in principal coordinates.
Type: double
results_ZP1
The plastic section modulus Pz in principal coordinates.
Type: double
results_areaEnclosed
If results_NumberOfCells is non-zero, this is a pointer to the areas enclosed by each cell of the section.
Type: pointer
solver_id
The solver ID of the entity.
Type: integer
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
