noisecontroltreatments
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
FIELD_ANGLE
Value of field angle of NCTs.
Type: double
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
internalname
The internal name of the entity.
Type: string
layer1
The first nctlayer ID.
Type: entity
layer2
Type: entity
layer3
Type: entity
layer4
Type: entity
layer5
Type: entity
layer6
Type: entity
layer7
Type: entity
layer8
Type: entity
layer9
Type: entity
layer10
Type: entity
moduleid
The module ID of the entity.
Type: integer
name
The name of the entity.
Type: string
numoflayers
The number of NCT layers ranging from 1-10.
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
poolid
The pool number of the entity.
Type: integer
poolname
The pool name of the entity.
Type: string
solver_id
The solver ID of the entity.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
solvername
The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Type: string
Version History
2022
